Hello! I'm adding a recirculating pump to my residential hot water system to reduce the wait time for hot water. I was able to run a return line from the furthest fixture back to the hot water heater. I plan to put the pump and a one way valve on the return line near the tank, but I'm not sure if I need to return the water into the bottom of the tank or if it can be tied to the tank's cold water supply line.
Connecting the return line to the cold water supply would be easier in my situation, but some places suggest that you must bring the return into the bottom of the tank by removing the drain. Does anyone know if that's required and if so, why?
Regards,
dwaun
Regards,
dwaun
