David
Howdy --- Hoping to get some insight guidance. I'm a DIY'er. I have installed a Rheem tankless system; dual unit, using their EZ-Link cable. I may get this wrong, but basically, once one unit hits 80%, it kicks on the second. The EZ-link basically controls this. Everything working great... except recirc. These units have a built in recirc controller, however it does not work in a multi-unit set up. So I hooked up my recirc pump like I would on a tank system; on the recirc line, and on a timer to kick it on for just peak hours. The problem I'm having is that when this pump kicks on, it creates just enough pull in the lines that the tankless unit wants to kick on. However the water flow isn't strong enough, and the unit error codes and sometimes needs to be reset. The error code is P1.
Thoughts? input? How can I get this to recirc? Would rigging up an aquastat help in anyway? I
see attached pic... my late night, couple cold ones, work.
