Recessed light over shower
GabeS
Remodel Contractor
Brooklyn NY
Speedy,
You still haven't explained to me how a GFCI is not safer than a regular outlet.
The reason you can't explain it, is because you know that a GFI IS safer than a regular outlet. The same way a ARCI breaker is safer than a regular breaker.
I can't believe you're saying that someone wouldn't be safer with a GFI. I thought you said you were an electrical instructor.
Speedy Petey
Licensed Electrical Contractor
NY State, USA
I NEVER said that.
My opinion is why do you need the extra safety? A properly wired and grounded circuit is almost as safe as having a GFI.
If you understood why GFIs are required in the locations they are, and that typically only receptacles require protection, you would see my point.
Properly installed lighting does not pose a threat, but people do stupid things with things that are plugged in to a receptacle.
Thing is people are STUPID!! If they were not we would not need half of the codes and laws we have today.
GabeS
Remodel Contractor
Brooklyn NY
I NEVER said that.
You were confused and perplexed when I said I would feel safer with a GFI connected to a light switch that I would flick on or off while wet in the shower.
Speedy, you ask why do you need the extra safety? The answer is to be safer.
The same reason they are requiring AFCI breakers on most circuits. To be safer. Do you think it makes sense to ask why do we need the EXTRA safety?
Are you kidding me? Are you saying that electricity flowing through a house cannot become potentially unsafe. It's electricity my friend, it can kill and has killed. If there's a way to make it even a little safer, I'm all for it. Someone else chime in and please tell me I'm not going crazy.
JWelectric
Electrical Contractor/Instructor
North Carolina
So let’s instruct. ;)
Let’s think about what is happening when we GFCI protect a receptacle. A receptacle is a place where a cord is plugged into that has an electrical appliance on the other end. This means that the electrical appliance is portable and in most cases easily moved from one location to another such as a hair dryer that is moved from one angle to another while in use.
A switch on the other hand is never used as a receptacle. It never has a portable appliance plugged into it that is easily moved from one location to another location. A switch is located in a box is for the most part is flush with the wall. There are no exposed live parts that someone could come in contact with such as the slots of a receptacle.
Some lights when installed in a wet location are required to be protected by a GFCI device. In such cases a light when on produces heat and should cold water come into contact could cause the bulb to rupture and expose live parts that are internal to the bulb.
A switch on the other hand is never used as a light fixture. It never has bulb that could break. A switch is located in a box is for the most part is flush with the wall. There are no exposed live parts that someone could come in contact should the bulb burst.
In summary it is real easy to understand why a receptacle would need GFCI protection in wet locations and why some light fixtures would need to be protected but not one reason to protect a switch.
Class dismissed :D
Speedy Petey
NY State, USA
"Perplexed"?? You certainly are one for the drama.
No, I don't think I was.
No, it's because the manufacturers lobbied the code making panels and to prevent litigation in cases where that stupidity I mentioned rears it's ugly head. The ONLY thing we need to be safer from is ourselves!
Whoa! Back up, and do NOT put words in my mouth. That is NOT what I asked or said.
Of course it can become unsafe if there is damage or someone messes with it who should not be messing with it. Or if someone did not install it correctly in the first place. THAT sir is my point.
I HATE being coded into a corner because Johnny Handyman is a hack and we need to write new codes to protect him !!!!
GabeS
Remodel Contractor
Brooklyn NY
Ok. I see everyone's point.
Not sure I agree with the ARCI theory. An outlet can produce an arc that wouldn't trip a regular breaker, but would trip an AFCI.
Petey, you're right that Joe Homeowner is never going to stop messing with systems in his house that he doesn't understand because that's just the way people are. Call them stupid or call them whatever, that's how it is. When it comes to home repairs people do stupid things. The right way, nah, why would anybody want to do that. It's too boring to do it that way. :D
BurleyMike
SE Idaho
No matter how many GFCIs or AFCIs you have bad things can still happen. Just look at one of my favorite videos to see the kinds of things that can go wrong with electricity. While this is not something that happens often it can happen.
Jar546
USA
www.inspectpa.com
Gabe,
If you want to feel better protected then a GFCI breaker feeding the entire bathroom circuit is a better idea.
The GFCI receptacle only protects what is plugged into it or what is downstream of the load side if used.
An AFCI breaker is also a great idea for arcing and sparking issues.
GFCI protection is not foolproof and there are ways in which a GFCI will not trip and you will be electricuted. If there is not path to ground during the fault and the GFCI senses the exact same current on the feed and neutral then it will never trip.
The 2008 codes add a significant amount of GFCI and AFCI protection to homes. We are still on the 05 in our area.
GabeS
Remodel Contractor
Brooklyn NY
Jar, you're right. Good point.
The only thing I don't like about the GFCI breaker is that it's more unlikely to get tested every month or two because it's stashed away in the panel and probably gets neglected. Whereas the outlet is right in front of your face everyday and will likely get tested more often than the breaker.
Besides, you can just bring the feed for the bathroom directly into the GFI outlet and feed the rest of the bathroom off the load to protect the entire bathroom.
Don't know myself what the stats are to which one lasts longer or operates better.
I heard that they are trying require every circuit to have AFCI. Is this true? Is this required in the new code? Could get pretty expensive.
JWelectric
North Carolina
210.12 Arc-Fault Circuit-Interrupter Protection.
(A) Definition: Arc-Fault Circuit Interrupter (AFCI). A device intended to provide protection from the effects of arc faults by recognizing characteristics unique to arcing and by functioning to de-energize the circuit when an arc fault is detected.
(B) Dwelling Units. All 120-volt, single phase, 15- and 20-ampere branch circuits supplying outlets installed in dwelling unit family rooms, dining rooms, living rooms, parlors, libraries, dens, bedrooms, sunrooms, recreation rooms, closets, hallways, or similar rooms or areas shall be protected by a listed arc-fault circuit interrupter, combination-type, installed to provide protection of the branch circuit.
Beekerc
IT Consultant / Network Engineer
Seattle
a sad truth. i don't know which is more disturbing, that people actually lack common sense, or that they don't actually lack it, but are too lazy to use it.
agreed, but as is pointed out below, just as GFCI's can malfunction, so can switches, and the point about being went and in contact with a switch is a valid point. this is why i opted feed the shower light, and switch, off the load side of a GFCI outlet that is requred in the bathroom (due to it's proximity to the sink).
In another thread I talk about wanting to have a GFCI that has both green (properly operating and protected) and red (fault/tripped) LED's. I found the Hubbell self-testing GFCI line. I opted for the faceless unit, but i'm sure they sell receptacled ones. the nice thing is the red LED flashes when it end-of-life's and is no longer able to protect. a great feature, and not a cheap one, but if it keeps you and your family safe, are you really going to squawk over a few bucks?
Even though the receptacle is "in front of your face", it still requires a conscious effort on the owner's part to actually to the testing - see my first response to Speedy's comment. This is why the Hubbell self-testing GFCI is so attractive, even at the additional cost.
Would it be safer if the whole house had GFCI protection?
sure it would, but then factor in the inconvenience factor of having surge strips and surge protectors tripping the GFCI units and killing power to computers, tv's, home theaters, or anything else worthy of surge protection..
JWelectric
North Carolina
The truth of the matter is that most people use slang such as outlet when referring to a receptacle and this makes the knowledge level drop drastically. With out knowledge then common sense hold no merit.
If a switch is properly installed and the switch fails to the metal yoke then the equipment grounding conductor will open the overcurrent device. A fault to the yoke is the only way that a switch could be dangerous and if the EGC is not in place then it wouldn’t much matter if it was in a bathroom or not.
Across the big pond whole house protection for Ground Fault and Arc Fault has been in place for the service disconnect for many years. There don’t seem to be any problems over there with surge devices as seems to be over here. Then again the surge protector that I am using right now and protected by a GFCI receptacle hasn’t tripped as yet either. It has been in place from early 2001.
Probedude
California
Was that bucket lift to blame?
Alectrician
DIY Senior Member
I also want to install a ventilation fan that will run off the same switch as the recessed light above the shower
Put it on a seperate switch. The light and fan serve very different functions.
Install a timer/switch. Leviton makes a slick decora syyle that has 5, 10, 15, 20 minute settings.
And Gabe....if it makes you feel better, if I was standing barefoot on wet tile slab floor and the switches were GFCI protected, I too would feel safer. I have been stung a couple of times via a cover plate screw. It happens.
Beekerc
Seattle
recessed shower light
not completely necessary. if all you have is a 1-gang box. both leviton and broan/nutone make double and triple stacked switches for bathroom light/fan use. broan even makes one that's a triple stack, one for fan, one for heater and the bottom is a double rocker for full light or night-light
personally, i like the 10/20/30/60 minute version. i replaced all my spring-loaded turn knob timer switches for ventilation fans and heat lamps with these push button ones.
TheElectricalGuru
National Electrical Code Expert/Speaker/Educator
www.TheElectricalGuru.com
Well the sad fact is and I quote " You can't Fix Stupid " so no matter how NO BRAINER we make it someone will STILL screw it up and thus nothing can be made idiot proof.....we can only work to make it USER friendly.:eek:
