Rebuilt Pump - Still leaking around gasket
Mjkarabela
Ontario, CA
Hey Fellas,
I got this old Duro K-255 piston pump. Last night, wasn't holding prime over night, so took it home and rebuilt it. However, there is still like 5 drips per 20 seconds coming out around this gasket, not under pressure. The mating surfaces are a bit pitted, but I was hoping the gasket would take care of the imperfections. I've never rebuilt pumps before, the cottage is 2 hours away, is this normal after a rebuild? Will the little holes rust up and clog and we'll be OK for another couple years? Or if I put it underpressure is it going to spray like a spray nozzle on a hose when it's not on properly?
I'm thinking the only other option is to get the surfaces machined...
Looks like that is on the low pressure side? If so, that is why you are losing prime. Probably won't rust up and stop leaking with a gasket between the surfaces. Silicon the gasket and let it dry.
Thanks for the input. Not sure if it's the low pressure side or not - this is basically the pump
So I should:
1 - Take it back apart.
2 - Clean the surfaces.
3 - Put a small bead of silicon on both sides of the gasket. Any particular type of silicon I should use?
4 - Put it back together while it's still wet
5 - Let it dry
and voila?
I was also thinking putting some JB Weld on the surfaces, and then sanding it smooth.
