BirchwoodBill
I am reviewing the one document done by the last professional who installed the Warmboard manifold 18 months ago. He walked off the job with the heat not running leaving me to hire another person to install new valves to bleed the air out of the system. Two of the three Honeywell Zone Valves also have bad end-switches - (Yes the original contractor did get paid without the heat running in the house).
The document (attached) left by the original contractor has the instructions to "Pull Check Valve" out of the two recirculation pumps (Grundfos UPS15-58FC). However, I don't see the "Check Valve Removed" label on the name plate of the pump. So I don't know if it was pulled or is still installed. The larger question is what is the reason WHY the check valve would be pulled out of the two pumps. The indirect has its own Taco-007-ZF8-9 pump.
Trying to determine if I can re-use the pumps when I upgrade the boiler to a mod-con and move all of the CH over to the manifolds (Rehau Pro-Balance).
