wwhitney
I'm familiar with the idea of a pump curve, and that if you have a distribution system performance curve (how much water will flow in the pipes to the outlets for any given constant pressure source attached to it), the system behavior is determined by where the two curves cross.
So what does it mean when a published pump curve doesn't intersect both axes? Say one endpoint is 5 gpm at 50 psi; why isn't the curve extended to show (to make up some numbers) 1 gpm @ 52 psi and 0 gpm @ 53 psi? Is the manufacturer indirectly saying "do not operate below 5 gpm?"
A related question on charts, like the one below that came up in another thread, for this pump: https://www.pentair.com/en-us/produ...2-hp-thermoplastic-sprinkler-system-pump.html That pump is specified as "maximum discharge pressure 50psi". So what happens if you hook up the 2HP model to a system that will flow 10 gpm at 50 psi and 14 gpm at 60 psi?
Or what happens if you connect the 1.5 HP model to a system that will flow 15 gpm at 45 psi and 18 gpm at 50 psi? Should the - entries be read as 0, so that with 5' suction head the 1.5 HP model has a maximum outlet pressure of somewhere between 45 psi and 50 psi?
Lastly, for pumps in general, does inlet suction pressure trade-off one to one with outlet pressure (for suction pressures below ambient air pressure)? I.e. if you have the pump 7.3' above the water source, is the outlet pressure 1 psi less than the 5' row for each of the flow rates given, as 2.3' = 1 psi? If so, can we conclude the 1.5 HP model would actually do ~ 8 gpm at 5' suction head and 50 psi outlet pressure, even though that table entry is not shown? [Should be close to the table value for 15' suction head and 45 psi outlet pressure, as 10' ~ 5 psi.]
Thanks,
Wayne
P.S. I hope the phrase "suction head" is OK, I'm just using head as a synonym for pressure.
Thanks,
Wayne
