stardog
Reporter
This is really a "wiring 101" type question, but I've always been curious about this. When wiring together on the same circuit multiple standard (non-GFCI) receptacles, does it matter the order in which the hot and neutral wires are connected to each receptacle. Obviously, hot goes to the brass screws and the neutral to the silver screws, but is there a particular or preferred order to attaching the wires to each receptacle.
Question 1: When connecting the first receptacle to the second receptacle, does it matter whether the hot gets attached to the top or bottom brass screw on the second receptacle?
Question 2: In the same vein, does the neutral wire coming into the second receptacle have to always be paired with it's hot wire? For example, if the hot is connected to the top brass screw on the second receptacle, then does the neutral wire coming in have to be connected to the top silver screw as well?
Or does the connection order not matter at all, as long as all "hots" get connected to any brass screw, top or bottom, and the neutrals get connented to any silver screw, top or bottom?
At the end of the run, does it matter whether the top or bottom screws are used on the last receptacle, as long as hot and neutral are in sync (either both connected at the top, or both connected at the bottom)?
Just something really basic that I've never seen clearly addressed anywhere. Tks for the learning experience .
