guht
I have some pipes that are rattling in my upstairs bathroom. It has dual sinks, and both sinks will cause the problem to happen.
If you turn on just the hot water, and leave it on for 30-60 seconds, the pipes will start banging in the wall.
If I turn on the cold water half-way to full, while the hot water is still on, the rattling will stop.
It does not do this in the bathroom shower , which is located only a few feet away from the sinks.
The hot water heater is located in the garage, which is not quite directly above this bathroom, but in close proximity.
Can I fix this myself, and if so where would I start?
Additionally, this may or may not be related, but might be worth mentioning just in case. When running the washing machine downstairs, also close proximity to the hot water heater, it seems like when the washing machine is switching between using water and not using water, it makes a singular loud clunk in the walls. It doesnt rattle on and on like upstairs bathroom, just a loud clunk. I usually run the washing machine with at least some hot water. I havent tested to see if it does it with just cold. Need to try that!
Thanks for reading.
Thanks for reading.
