I recently moved into a new home that has a 50 gallon water heater plus a hot water recirculator pump ( Grundfos UP 15-42F and a Honeywell aqua stat L6006C set for 130, 5 degree differential.
My problem is the hot water runs out way too early; about 10 minutes into a shower. The temp on the water heater for both the upper and lower are set to ~140 but the temp coming out of the nearest faucet starts at about 127 and rapidly goes down to ~99 in less than 7 minutes.
I think there is a crossover issue as I turned off the cold water supply to the water heater and turned on the hot water outlets in the bathrooms. The master shower runs when I turn on the hot water. Is this the cause of my running out of hot water?
Thanks for your help.
