Blacktail
Hello...new here. We have a 260' well that produces great water but not alot of it. I am currently devising a system of ibc totes to harvest rainwater off of my metal roof shop. These totes will fill a 500 gal. black tank thats inside the shop via transfer pump and thru a filtering setup. The well can also fill the 500gal. tank but the well just doesnt have the output to maintain it. So at the filters it will be a dual in dual out with valves ie Totes and well to inlet filter and filter outlet tote/well to black tank and or well to pressure tank. Once the black tank is full a 1hp shallow well pump with 30/50 switch will pump water from black tank to feed the pressure tank (30/50). I plan to install a uv light between the pressure tank and house for obvious reasons. My question is this ok to install the uv light after the pressure tank or should it be before. Hope this isnt to confusing. Would be nice to actually do laundry or have a garden etc. Thanks!
