Rainbird Solenoid (again)
Minka22
Fort Worth
I didn't see this issue on any other posts, so........ when I turn a solenoid "on" 1/4 turn, nothing happens, not for any of the four of them. 1/2 turn or 3/4 turn, still no water comes out of the sprinkler heads. How can this be? It's supposed to manually turn the water on. I know the water is on, the sprinklers spray when I test the each station from the control box.
A second item if I may: the reason I am messing with this is I have 3 stations that come on and stay on while each other station is supposed to be on by itself. From all the YouTube videos this likely means the valve for the 3 stations is stuck open due to debris in the line, so I was trying to get to the valve to flush it out. But my 4 valves are not neatly tucked away in a corner above ground as commonly seen, but rather are scattered in 4 separate locations around the front and backyard, about a foot below ground in a 9" diameter plastic cylinder. They are usually full of dirt or mud. Only the solenoid is visible; the valve is in the dirt. Should I pull up the plastic cylinders, dig out around the valves and find a way to raise them closer to the surface and cover them with a bigger plastic box? The system was put in in 2005. Thanks y'all.
Minka22
Fort Worth
Well, I have a Rainbird Controller so I assumed I had Rainbird valves and solenoids, but further (literal) digging shows I have some other brand, I can't tell what it is yet. Replace them all with Rainbird? I would like to do this myself unless it becomes obvious that I cannot.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
Plastic valves get used a lot. Brass is great if you can afford them.
If your valves are in the ground, then the entire system must have a primary backflow preventer supplying those valves.
Pulling the valve box is usually the only way to deal with bad valves, either to rebuild or replace.
WorthFlorida
Currently under Chemo Treatment.
Solutions
Orlando, Florida
All valves are nearly the same regardless of the name brand. Any valve with any controller will work. Your problem sounds like you have a Master Valve. It's placed before the irrigation pipe branches out to other zone valves.
