maliolani
Can someone please clarify something for me about using the Rain Bird ESP-me controller?
Suppose you have the system programmed to have only one Program (A). B, C, and D have no start times and no run times. Suppose you have 3 stations on program A with run times of 45 minutes each, supposed to start at 12 noon, and for the sake of argument let's say that it is set to come on every day. But your timer is set to OFF. So at 1:30 pm you go out and use Manual Program to run all 3 stations on program A (and you set the dial to Auto while it is running), which works fine. But then, about 4 hours later, you go out and find that station 3 is still running. So here is the question:
When the manual run of the program finished, it was about 1:30 pm plus the 2:15 run time, or about 3:45 pm. Is it possible that the sprinkler timer then decided to run the programmed run that should have happened at noon that day (but the timer was set to OFF at that time)? In my mind, first of all the timer should not run programs for which the timer was set to OFF when the start time came around, plus it seems to me that since I ran a manual program, I had already watered according to the program that day.
But if the timer did NOT decide to start the "missed" auto program after the manual program, then why would it still be running long after the manual program should have finished? I have confirmed that there is NOTHING for programs b, c, and d, and that there is only one start time, at noon. I'm confused why the timer ran ANOTHER program after my manual program started. Obviously there is a 99.99% chance that I'm not understanding something and a 0.01% chance of an equipment malfunction. So please clear up my misunderstanding.
