2002sheds
Hi All,
Our house is heated by a 2 zone open-loop radiant system with PEX. We occasionally need to clean out the sprayer diverter in the kitchen sink faucet and the supply line itself (when it is really badly clogged with grit).
I installed a fine mesh filter on the cold water supply pipe before it reaches the water heater (or anything, really), but it has done nothing for the grit that is already in the nearly 2,000 feet of PEX. I'd like to install another filter ahead of the domestic hot water line, but I can't quite wrap my head around the plumbing, so I am unclear of where to place it.
Below are pics of the system, from outside and inside the structure. My question is this: How does the water heater "take in" water from the pex loops in this system (when domestic water is not being used and heat is called for, activating the re-circulation pump)? It seems to me that the pressure from the source line would be greater than the pressure from a -re-circulation pump, but I really don't understand, so that is just a guess.
I am asking because I would like to determine where to place the filter, and trap that grit.
David
David
