RLMELL
I'm a homeowner in California and first time poster. I'd like to install the Rachio flow meter. Flow meter must be installed above ground on the downstream side of the back flow preventer and requires a 3/4" or 1" pipe. Pipe must be Copper, PVC, PEX or SDR9 poly. My back flow preventer is connected to 1-1/4" galvanized pipe. I was wondering if it is possible/meets code to downsize the downstream pipe off the back flow preventer to 1" PVC, or if that would somehow affect the performance of the back flow preventer? I would assume it wouldn't given that the in ground pipe that the back flow assembly is connected to is 1", but I don't know. I've attached a picture of the back flow preventer if that helps at all. Thanks
https://www.rachio.com/wireless-flow-meter
