As a regular regeneration is configured to use only 12 lbs salt, to restore even more capacity to reduce ongoing hardness leakage, it would be advisable to add an additional 2 gallons water to the brine tank using a bucket prior to each manual regeneration. Waiting about 1 hour after adding the additional water before starting each regeneration will allow sufficient time for additional salt to dissolve.
To restore the total capacity of the 2 ft3 resin would require 40 lbs of salt, but between the 2 manual cycles each using 2 extra gallons, 36 lbs salt will be used which will restore a more than adequate percentage if the total capacity to satisfy your needs
Yes. If you go from BF=8 to BF=9, you could add 0.5 gallons of water to the brine tank 2 hours or more before the regen to start with what you would have had if BF had been 9 previously.However, after this auto regeneration 22 days later, the water feels a little harder. The gallons generated were 2483 with settings listed above. How do I keep roughly the same number of gallons softened with similar capacity (C = 40) but increase the quality (softness) it my water? Can I keep C = 40 but increase BF = 9? If so how many gallons of water should I add to the tank before doing a manual regeneration?
I would go to BF=10 for 7.5 lb/cuft. It is still less than the popular 8 lb/cuft. If the water feels too soft, you could back off to 9. See post #2 on this thread.
Gallons on the display after regen will be (C/H-R) where C and H are the softener settings, and R represents the reserve in gallons. If RS=rc, then R is the RC value. When the display counts down to zero, regeneration will happen the next time that RT matches the current time.Overall, I do want to keep # gallons regenerated the same (<3000). Which is the better option? Thanks
This will not waste resin or capacity. What it does do is use additional salt compared to the salt amount needed to regenerate 40K Capacity. Since your concern is with the quality of the softened water, then using a little more salt to obtain the water quality you want, would be a reasonable tradeoff.Is there any detriment or wasting resin to keeping C = 40 and BF = 10?
10 minutes BF X 0.5 BLFC = 5 gallons fill X 3 lbs/gal = 15 lbs salt
40,000 / 15 lbs = 2,666 grains per lb of salt Hardness Removal Efficiency
9 minutes BF X 0.5 BLFC = 4.5 gallons fill X 3 lbs/gallon = 13.5 lbs salt
40,000 / 13.5 = 2,963 grains per lb of salt Hardness Removal Efficiency (approx equal to 48K capacity while using 16 lbs)
Hardness could have accumulated in the pipes. Over time that hardness gets moved into the passing water and gets used. The water to the second story goes through more pipes. So that's how it could happen.Question: is it possible to have the water on the 2nd level of 2 story home feel less soft than downstairs? If so, any reasons as to why?
Do you not have an Hach 5-B? Better than touchy-feely when figuring out hardness.Would it makes sense as to the reason why? Or could it mean a different problem?
Even small amounts of hardness can make "soft water" feel less soft. http://wcponline.com/2012/03/05/soft-soft-water/ This is an article by Chubb, one of the most brilliant minds in the water industry. This article is a total "101" compared to some of his articles, this maybe why I liked this article so much
The "Silky" feeling tends to diminish over time as your brain is trained to what should be normal. Like when you get a new car with more HP, after a few months it simply feels "normal".
