I do maintenance on a rental house that has poor water pressure when multiple faucets/fixtures are in use. It shares a line with the neighbors who have the same issue. The problem originates from the line coming into both house. Ive removed the water meter and turned it on to verify the pressure was low at the source. The washing machine when in use allows for very little water elsewhere. And with tenants living upstairs and on the main floor its a problem.
I'm curious about the pressurized tanks. Ive read that you can use the tank by itself(without the pump) for storage of water to help out when there is a great need, such as filling a bath tub or the washing machine in is use for a large load. Can I assume there's some truth to this helping with the problem? If merely using it as storage of water, is there a need to add in the relief valves, and pressure gauges and all that stuff i see online? i don't plan on adding a pump.
A while back I tried a pump that hooked directly into the water line just after the meter. It really didn't increase pressure in the house, and the neighbor said he was unable to get any water while that was running.
So I'm hoping a 10 gallon tank (or larger) of stored water could for the most part solve this problem when a lot of water is needed over a short period. Any insight into this matter would be greatly appreciated.
