DEWFPO
Hi,
I have 2 questions regarding the above.
I need to install an expansion tank on my domestic water system.
I was planning on installing it on the cold water side of the gas fired water heater.
My street pressure is 127 lbs, knocked down to 75 psi by a Watts PRV.
I have a 50 gallon hot water heater.
Based on the charts that I have looked at, my conditions put me right at the line between needing a 2 gallon expansion tank and a 5 gallon expansion tank. Those are the only 2 sizes of domestic tanks that I have seen around here. (No 3 or 4 gallon tanks).
Question 1.) Which size tank should I go with. (in the winter, the water coming in from the street is pretty darn cold. Lots of expansion when it hits the hot water heater.
Question 2.) The fitting on the expansion tanks are ¾ inch. I have the availability to easily tap into a ¼ inch line that ran to a humidifier, or a ½ inch line. Do I need to tap into the ¾ inch main line to keep it ¾ inch all the way to the expansion tank from the water heater inlet pipe or can I use the ¼ inch or ½ inch existing lines which would be easier to use.
Thanks in advance for your thoughts and answers.
DEWFPO
DEWFPO
