James23912
I am installing an exterior weather resistant GFI outlet, it will rarely be used, but it is right above the panel inside so first in line to other outlets in the house, so I would prefer not to have it shut down the whole circuit, so can I bypass it for the rest of the outlets inside?
There are holes on the back, actually 2 holes over each screw, 8 total, so I am wondering if this is so I can use only the line side? I was figuring I would need to make a pigtail. Also, the screws are in tight and when I loosened them, they are very short and it does not seem like I could attach the wires to the screws, I don’t use the push in holes normally. Thanks.
