Question on floor drain for water heater
James55
Washington
I have to install a floor drain for a water heater that is located in a closet. Installing the drain is not a problem. My question has to do with how the water heater TPR valve drains.
1. Do I set it up so that the TPR valve drains into the water heater pan, and then have the water heater pan drain to the floor drain?
2. Do I set it up so that the TPR valve drains to the floor drain, and the water heater pan drains to the floor drain as well?
I live in Washington state, and haven't been able to get a clear answer to this question.
Thanks in advance,
James Thomas
Sylvan
Still learning
New York
When I am faced with something like this in Manhattan high rise
I place T&P discharge above the floor drain and have the pan drain separately .I do not know your area code requirements
James55
Washington
I'm not sure about Washington state codes either. I'm not a plumber, so would probably not understand the codes if I read them. Thanks though! I was looking at the setup and the TRP valve is facing 180 degrees away from where I would put the drain. That will make it harder to get this right.
