Davud
Hello,
I'm trying to determine whether or not I my home's water supply is equipped to install one of those shower rain heads along with a handheld for a master bath remodel. I have a pretty low PSI but they flow rate is decent, from what I've read.
For reference, here are the specs, along with some info behind them.
Pressure: 35-36 PSI.
This was tested at two spigots and also confirmed by testing from a serviceman from the Water company.
Flow rate: 11.1 GPM
I calculated this by turning off all water faucets in the house, then using a 3/4" drain I installed directly adjacent to the meter at where the city supply directly enters the house, then timing how long it took to fill a five-gallon bucket (see the attached picture where the valve I tested from is circled red, for reference). When I refer to it as a "drain", I mean that in the sense that if I want to drain all the water from my house, I do it there. I'm sure there is an official term for it.
Also for reference, I'm completely remodeling the house, so right now walls are open. So if any of your thoughts or suggestions would be affected by this knowledge, just a heads up - I can make just about any modification you'd recommend.
So as for my question, I've been wracking my brain over trying to figure out whether or not I can install the shower system I want by researching homes with my PSI and flow rate as a way to compare, when I finally figured there is probably a common sense test that I could do instead. While it wouldn't be fool-proof to any degree, it would probably give me the best indication of whether or not my desired shower setup can be done.
I'm planning to simulate a likely "worst case scenario". I want to run my kitchen sink warm at full blast, run the washer on warm, run one of the master bath faucets on warm full blast, and run the dishwasher (the reason I'm specifying warm is that it will utilize the same mixture of hot and cold my shower will generally be). Then immediately perform the five gallon test at the shower on both the hot supply and cold supply.
(note: I understand this is not the "true" worst case scenario, but I figured it's just me and my wife, so the odds of us having any other fixtures running at the same time is highly unlikely, and if we did, then we'll just have to deal with getting dribbled on in the shower ;-) )
If it turns out my flow is, let's just say 5 gpm for both hot and cold for example, would this mean I would be safe to install the shower system if the combined total flow of the rain head and handheld does not exceed 5 gpm?
And on this note, I could also hook up some temp male threads to mount my pressure gauge on to test the pressure, as I know the fixtures also tend to specify PSI requirements.
I know there is a lot that goes into determining this, but I just sort of figured this has to be a relatively decent approach, since it gives the exact PSI and flow of my hot and cold supplies at the exact location where they're to be installed.
Thanks in advance for any advice you guys can give me, I really do appreciate it!
Flow rate: 11.1 GPM
