Question on 17T Delta cartridge - lukewarm to scalding water...
KRC
San Francisco
I purchased and installed a R22000 valve body and 17T cartridge.
I have it all "working" but it doesn't really get "cold" water - so I question if this is by design. The cold must be working because the hot water does adjust from lukewarm to scalding, so the valve must be mixing. But I can't just get "all cold water" - so is that by the design of these cartridges? I also notice that if I shut off the hot line (I have a separate shutoff of the cold and hot lines), then no cold will flow, and vice versa. So there must be some sort of pressure balancing requirement as well from the inlet ports? I guess this will work, just seems odd that I can't get very cold water out of the valve - so I am questioning if there is something else subtle going on.
KRC
John Gayewski
Iowa
I'm not sure exactly the cartridge you'r talking about but there's likely a thermostatic adjustment that needs adjusted. It also seems like it should out of the box be adjusted to run cooler water rather than hot which makes me think you have something flipped.
Breplum
Licensed plumbing contractor
San Francisco Bay Area
I have faint recollection of this happening because the cartridge was rotated incorrectly.
After turning both sides off, remove the brass ring and make sure the v shape on the cartridge is into the notch provided in the faucet body.
Call Delta if that doesn't work.
KRC
San Francisco
Hey - I was able to work it out. I took it back apart and made sure that the cartridge was oriented correctly - which it seemed to be. Then I noticed that it was just "stuck" when turning CW to cold... but once I exerted a bit more torque then it went over fine. Maybe it was just a break in thing - the tool they give doesn't let you get much torque on the end gear to easily turn.
