Question of shower p trap moving
Sweendog92
Sunriver Oregon
So I have a shower pan that requires the drain to be moved from it’s current position closer towards the threshold three and a half inches but the problem is the trap will hit the water lines. I was wondering what I could do to navigate around the water lines
around the water lines? are they in the way or not? it looks like one needs move or possibly both. offset them with 90s or 45s
Tuttles Revenge
Offset the water lines and move the trap where it needs to go is the easiest answer. Unless you get lucky and the trap can go under the one pipe and up between the other..
