Davud
Hello. The supply line for my HVAC’s humidifier is 1/4” copper. After reading that saddle valves are almost universally panned by the pros, I’m avoiding going that route to tie it in to my main supply. I’m going to tee off an adjacent hot line (1/2”), then install a shutoff valve (also 1/2”), then planned to sweat a 1/2” to 1/4” reducer to make the final connection.
However, I haven’t found much info on sweating 1/4”. Most of the conversations discuss using compression fittings. I’m not opposed to compression fittings, but is there anything wrong Wuth soldering? Or maybe more complicated than it’s worth? (I did read on another thread where a member said you can’t use regular solder for 1/4”. But I honestly have no idea)
In general, if all things are equal, I’d prefer to solder than use compression fittings, but will ultimately do what makes the most sense.
Thanks in advance for any feedback and happy Presidents Weekend.
