Marcus Waddell
Hey all,
I need to run a 8/3 UF cable from my main panel in the house to my shed. Total distance is about 120 ft away, so for a 20A circuit that requires 8/3 cable. My question is this. The Table 300.5 in the NEC says 24" deep if using Column 1, but Column 4 says if it's a 20A GFCI protected circuit then you only need to bury 12". Since I'd still be using UF cable, do I need to follow Column 1 (24" deep) or Column 4 (12" deep). Thanks in advance.
FYI, this is just for a few outlets and a couple of LED lights in my 12x16 shed. Only 60ish feet is outdoor, the balance is the run from the inside panel box to outside.
