Question about check valve in horizontal installation of submersible
CanadaErik
Ontario
Hi there:
So I am planning to draw water out of a river close to my cottage and purchased a 4 inch 1 hp submersible Sta-Rite Signature 2000 with a Franklin motor. I needed to mount it horizontally in the river since the river get's down to about 3 feet at low water in the summer. My question is, with the pump mounted horizontally, will the check valve in the pump work properly? I seem to be losing pressure and am pretty sure there is no leak in the poly.
Thanks,
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Check valves usually work fine on the side. But I prefer a spring loaded check valve, especially for these applications. If it is not spring loaded, add an additional spring loaded one right at the pump head before the pipe.
Sylvan
Still learning
New York
Using a spring loaded check valve will cause even more friction loss (pressure drop)
http://www.simmonsmfg.com/index.php/our-products/check-valves/check-valve-stemless/
The graph seems to show about 1 PSI drop at 15 GPM for a 1-1/4 check valve.
The Apollo ball cone check valves (they have a spring too) seem to have much less pressure drop. http://www.apollovalves.com/_literature/cat_PHBRCHV.pdf says the 61LF-106-01 1-1/4 inch check valve claims only a 1 PSI drop at 44 GPM.
It would be interesting to compare others.
