Qest tubing
mikemc53
Michigan
I have an older mobile home (1996?) with the grey poly Qest tubing for all the supply lines. No leaks (yet) but also no shut-offs at any location except where the supply actually enters the home. I want to change out the faucets in the bathrooms and kitchen and also put shut-offs in while I'm doing it. At that time I would also like to transition from the poly to either cpvc or Pex. My preference is to use some type of push connect fittings but I am not sure what works with the poly. SharkBite makes some poly conversion fittings but I have not seen them locally. The Qest tubing is 1/2" with the 5/8" OD like cts, or Pex. Could I use a standard 1/2" push connect on this?
Obviously I am looking for the easiest way around this. I have used push connect in my other homes with copper and cpvc, and they have always worked well. Of course, the off-brand connectors have had a few issues but SharkBite always seems to have worked.
Any and all help is greatly appreciated.
Thanks.
From what I've read, the Quest tubing has been problematic...when cutting bits out, cut out as much as you can easily get to when replacing things.
