wwhitney
FWIW, I think we've heard here in this forum from a plastics/solvent chemist that the above ideal is mostly true for ABS, but much less true for PVC. PVC is much harder to get "melty" (to use a technical term : - ), hence the need for primer. And the resulting joint, while strong, is still weaker than the base plastic.A properly glued joint is a type of weld. It should hold whatever the pipe will hold. Most joints are not properly glued.
Cheers, Wayne
