Reliable. My assessment is not based on experience. I would grease the gasket with silicone grease, because I like greasing gaskets with silicone grease. But even if I did not, I don't see a leak happening when putting the Push-Tite into PVC or ABS. IMO, these are especially good for less practiced people, because you don't have to get it right the first time, as you do with glue.I am planning on installing a push in flange during my second floor bathroom remodel. Are they reliable, will they leak over time
I don't know what you are describing, but it is not going to happen, whatever it is.if the gasket gets slopped out from flushing vibration?
I see what you mean now. You could add a block/wedge between the joist and the PVC to limit travel.I used plumbers tape to attach elbow to blocking but it still has some vertical movement. If there is movement with each flush over time won't that degrade the seal the gasket is providing?
Cool. I would not be surprised to your photo being referred to for a future solution. I had read https://www.pexuniverse.com/uploads/docs/pdf/sc-fl-ext-pushtite.pdf but I had a wrong picture in my head.It actually is a souix chief 887-GPM that I cut in half and have a 3" pipe in it to extend it.
Marked picture shows where I was thinking. It would limit upward movement, and the strap eliminates downward movement.Do you mean shim between drywall ceiling and bottom of elbow?
Why would you say that?A push-in flange that will fit into a 3" pipe will have an opening closer to 2"
There are inside fit flanges that will fit into a 3" pipe (however attached, whether glued in or pushed in). Not recommended on a 3" pipe IMHO, even if it fits. If your pipe is a 4", yes, you could use one, but it would reduce the ID to close to 3" because of the wall thickness of the flange plus the depth of the gasketing material. 3" ID is fine, 2" isn't IMHO. For any toilet sold in the US, a 3" pipe works fine, but reducing it further with an inside fit, even if allowed, isn't the greatest thing.
Ok my initial line was 2 3/4 I will stick with it. Will let you know how it turns out Reach. Planning on installing a Toto drake.A range will work quite well, but I think I would split the difference to put you about in the middle of the range.
