Jdbs3
Tiling a floor and will first remove a vanity. The copper water feeds come through the bottom of the vanity; the holes are just big enough for the water feeds and the PVC drain pipe.
After installing the vanity, the builder added shout-off valves. So the only way to avoid destroying the bottom storage floor of the vanity is to cut the vertical water pipes below the shut off valves and use a push-fit as a temporary solution until the vanity is ready to be re-installed.
I'll debur the inside of the pipes, and use a Scotchbrite pad to clean the tubing.
However, the deburring will most likely leave some residue in the pipes. Once I remove the push-fit and re-sodder the shut off valves back on, I can always flush the lines for 5 minutes. Anything else I can do to get the bur residue out of the line?
