Hello group, this seems like an excellent forum, but I haven't found an answer for my pump/control problem from browsing/searching. Here are the basics: 'City water' was piped to our rural area early last summer (tremendous!) and we haven't used our well/pump much except for washing vehicles, house siding, garden, etc. and hardly at all this past winter. (And like people, sitting idle is probably the worst thing for a pump.) It's a Berks above-ground, 1/2 hp/3460/60, frame J56J pump, foot-mounted on a Wayne horizontal tank of about 15 gal. (1' dia x 30" long.) This is an old style bladderless tank, it simply must be drained of water occasionally to allow the tank to reaerate, otherwise it will cycle on/off frequently. It has a Square D Pumptrol 30-50 psi pressure switch (9013FSG2J21M4.) The pump unit sits inside a heated pump house above the well. It has operated great for us for 13 years (one prior new Pumptrol) and was provided new or reconditioned at that time by the prior owners, due to the prior pump freezing from losing heat to the pump house.
The pump ran ok this spring but recently I heard it running with no water leaking or discharging from the pump system anywhere. It was cycling periodically (but not rapidly) and the pressure was only about 20 psi. The motor was pretty warm but not extremely hot (I could lay my hand on it for several seconds.) I deaerated the tank and tried again but 'nothing,' no motor, no pressure, no water. Thinking a defective pressure switch was likely causing this I bought another Pumptrol 30-50, but again nothing happened when I connected electrical service (and I had carefully marked the wires for proper reconnection.) However, the new switch (info above) has a lever on the side for manually starting the motor/pump. When I moved the switch to manual this closed the contacts and the motor/pump ran and pressure began to rise -- but some kind of safety or timer kicked it off after 10 seconds. After a minute or so I could barely hear another metallic 'click' when the pump could be turned on again for 10 seconds -- I raised the pressure to about 23 psi after several attempts but it would go no higher and the motor was getting hot. The running motor/pump sounds the same as usual. I 'suspect' the motor/pump was running automatically in this mode with the old pressure switch, when I first noticed something was wrong.
I primed the pump via the 'city water' hose, hardly any water needed to be added. I cleaned out the small hard-hose tube from the pump to the pressure switch even though water was present when I disconnected it. I also removed the motor end-plate and found I could manually turn the motor and pump 'easily.' There is water pressure at the tubing connection to the pressure switch after manual operation, enough to shoot water across the 6' width of the pump house. But the pump will still not start in automatic mode and only runs 10 seconds when started manually. Oh, I also checked wire connections inside the motor end-plate cover to be sure they were clean and connected ok.
Can anyone tell me what kind of sensor or safety switch I am hearing turn off the system, and which then clicks back on after a minute or so? (For clarification, the Pumptrol contacts remain closed when the 'safety' kicks off the motor, in fact, if I leave the manual lever in 'Start' mode, the motor starts immediately when the unknown 'safety' clicks back on.) I first thought this 'click' sound was coming from the pressure switch, but I find no safety switch of any kind mentioned in Pumptrol's on-line spec's. I'm now thinking this may be a motor overload safety switch, but even if so, why doesn't the motor/pump start in automatic mode for at least 10 seconds like it does when manually started...? I hope someone who monitors this forum can help and thanks so much to those who spend time doing so.
Mac
Mac
