Just finished opening the cap on my well; gently pulled excess wires/rope just below the cap. I did not tug on them in any way. I did hear a bit of junk falling, after disturbing wires. Never saw anything; just heard it. Inserted garden hose. Started to run water into the well. Dumped a gallon of chlorine down the well. Came back in the house and noted that the pressure kept dropping. I thought that was odd. I confirmed the pump was on. 250 volts across the pressure switch. Very minor flicker in pressure gauge when I turn the pump on/off, but won't build pressure. Closed up valves to ensure there was no water going to house. Still not building pressure. Is the next step to call someone to replace the pump?
I am going to go listen at the well and see if I can hear falling water. I highly doubt I could have disengaged the pitless adapter, but I'm running out of ideas.
