AZgunslinger
Wire over or under arrestor? Check valve to far from pump?
I'm in process of installing a knew pump and using 1" poly pipe. My father jumped the gun on me and placed the check valve around 20' above the pump. He was planning on us putting 2 check valves on the drop. I then read the post here on check valve placement from 2009 and all the comments. So I've decided to just use the one near the pump instead of multiple. Will that check valve be ok if left were my pops installed it approx 18 feet above the pump it do I need to move it closer to pump? If so how close?
My second question is the wire and safety rope placement. Does it go under or over torque arrestor. I would imaging under the rubber of it and clamped in with it but the pump I pulled out had the wire running between the grooves of torque arrestor and over the clamps. They also had the check valve inside the arrestor.
Thank you for your time!
Well is 306'
Old pump sat at 180'
Static is at 98'
4" casing
New pump is a 1 3/4 hp Tulhorse
Well is 306'
Static is at 98'
4" casing
