I did some searching/reading but haven’t been able to find a solution.
I've been using a submersible pump plumbed vertical in a 1700 gal poly tank for almost 20 years. I have zero complaints about the water system except... A few years ago I upgraded from a 3/4 HP pump to 1 HP. Now we are getting cronic torque damage to the submerged PVC plumbing. This will be my 3rd repair in the past 3 years!
The tank is above ground being feed by gravity spring water used for irrigation. The 1 HP pump is suspended vertically by 1 1/4" sch 80 PVC and 2 rope lines tied to a stainless eye-bolt. The 1 1/4" exits the tank through the tank sidewall near its top rim.
I currently have about 4 feet of submerged PVC pipe above the pump with a check valve and a union, then the PVC elbow that exits the tank. The torque caused damage has always occurred between the pump and the union. The first failure was a section of the PVC pipe deformed and split. Last time a male fitting split at the treads. This time it looks like the damage is to where the pipe enters the union. I wouldn't mind having to do the repairs if they weren't so frequent.
I could use some ideas here.
Maybe black poly pipe could handle the torque better than the more rigid schedule 80?
I'm not sure how well the slip fitting would hold up.
I am aware of torque arrestors but don’t see the application with this setup because my pump cooling sleeve is not connected to anything...
I've consider using metal pipe near the pump but fear the torque will simply cause problems further up the line.
