Blero
Greeting All
Hello good people im glad i found this terry love forum. I hope you all good.
I recently replaced all, submersible pump 1.1kw, tank 13 gall or 50L ,and pressure switch. Someone did this for me, first time used old tank raplaced membrane but it failed to keep air, water leaked around bolts, purchased new tank 13 gall and i replaced by myself, searching over internet watching videos now i understand how the tank and pressure switch should work, tank was factory to 30 psi max 145 , i added more air to 33 ( will add more air once i get proper air compressor pistol gauge to make 38). I set my pressure switch to 40/60 is this safe setting or should i change? To 20/40, 30/50 40/60
I also learned about CSV is this safe to use with my setup. ? The CSV is expensive so i looked for similiar in my country i attached PDF will this work same as csv? Or is a different.
Thank you have a good day
