Pump sounds like its not primed but has water at priming hole
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Garnet, Jul 18, 2016.
  1. Garnet
    Garnet New Member
    Jul 18, 2016
    Manitoba
    I thought my shallow well jet pump had lost its prime as i had no water in house suddenly. I left tub and sink tap open and went to pump to see if i could prime it. When i opened priming plug there was water right there and overflowed out of priming hole so cant add water.
    Now no clue what could be wrong. Wondering if pump is shot or maybe pressure tank?
  2. Brian Cannon
    Brian Cannon New Member
    Jul 17, 2016
    Missouri
    What brand of jet pump is it?
  4. Garnet
    Garnet New Member
    Jul 18, 2016
    Manitoba
    Red jacet quick set jet pump
    50RJAS
  5. Brian Cannon
    Jul 17, 2016
    Missouri
    If I remember right those are for pretty shallow wells. If you have an amp meter you can see how many amps its pulling. If they are low it sounds like the water level may be to low for the pump to pull water or the shaft could be stripped that goes to the pump. Jet pumps can be very fickle creatures. They are hard to diagnose without having hands on them but that's where I would start by checking for low amps.
  6. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If water was flowing out the priming plug, I doubt that the well is too deep to draw from. Maybe you have a stuck check valve or a clogged filter?
  7. Garnet
    Garnet New Member
    Jul 18, 2016
    Manitoba
    When you say filter is that the same as a foot valve? Going to fight with check valve. Its new, only bout a week or two old. What would cause it to get stuck shut?
  8. Garnet
    Garnet New Member
    Jul 18, 2016
    Manitoba
    Is amp meter and multimeter same thing? Also, is that tested at the little control box right at pump? Do you run the pump while testing ?
  9. valveman
    Mar 15, 2006
    Lubbock, Texas
    The poppet in a check valve can go up too far and plug the water outlet.
    An amp meter will have a clip around claw on it to snap around a hot wire. You can clip it around a wire at the breaker, the control box, or even the pressure switch. And yes the pump has to be running to test for amps.
  10. Garnet
    Garnet New Member
    Jul 18, 2016
    Manitoba
    K dont have amp meter. Ended up pulling pump out from under house and just tested it with pail of water. Pulled water from pail fine. Grrr.
  11. Brian Cannon
    Jul 17, 2016
    Missouri
    What's the water level in the well?
  12. Garnet
    Garnet New Member
    Jul 18, 2016
    Manitoba
    Its high now. I am wondering if it dropped due to high usage and i sucked in a lot of air. Now that its back up not sure why i cant get it going again
  13. Garnet
    Garnet New Member
    Jul 18, 2016
    Manitoba
    Few questions on the suggestions. First if amps are low, does that mean the pump motor wont start? Or could it start but not be strong enough?
    If there was enough power to run the pump before, what would cause it to not get enough now?
  14. valveman
    Mar 15, 2006
    Lubbock, Texas
    You should be able to tell if a jet pump is running just by the sound. Low amps would mean the pump is running and not pumping any water. Then you have to figure out if the problem is a suction leak, low water level, or a plugged line like if the check valve sticks.
  15. Brian Cannon
    Jul 17, 2016
    Missouri
    If you pulled the down pipe and placed it in water and it pumped water the pump is probably good unless it's worn were it will not lift much water. Those pumps are for real shallow wells like 25' or 35' if I remember correctly. If you water level is deeper than that the pump will not be strong enough to lift the water out. If I was there I would check the static water level.
  16. Garnet
    Garnet New Member
    Jul 18, 2016
    Manitoba
    Thanks for the replies, really appreciate the help. Here is an update. Since pump kinda seems to work, I wanted to test my intake line before I put it back under the house. I ran a spare piece of pipe from my regular intake line under the house to where I have the pump now about an extra 20 feet. After I primed the pump and ran it for about a minute and a half I had water. So this tells me the pump is powerful enough. Now I got to test if itcan deliver to the house
  17. Brian Cannon
    Jul 17, 2016
    Missouri
    So if you tried it with known good down pipe I would change the pipe doing down the hole! I've actually have had a problem very similar to this. The old black pipe on the suction side of the down pipe had a crack going down the length of the pipe and would not pump or loose its prime. The crack would only leak out if pressure was supplied. Once we change the pipe all was well.
  18. Garnet
    Garnet New Member
    Jul 18, 2016
    Manitoba
    K so i pulled out a plastic cap on bottom of the pump and it was a long plastic connection, not sure what its called and cleaned it up. It was covered in rust. Put it back in and hooked back up to well normally. Everything works now. Kinda weird.
  19. valveman
    Mar 15, 2006
    Lubbock, Texas
    Not really weird if that was the jet assembly you cleaned up.
Similar Threads: Pump sounds
Pumps and Tanks Well Forum & Blog. Water is life. Well pump sounds weird Aug 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. pump sounds locked up. Jun 13, 2007
Pumps and Tanks Well Forum & Blog. Water is life. 6 Month cheapo pump update Sunday at 8:56 PM
Pumps and Tanks Well Forum & Blog. Water is life. Pressure Drops To Zero When Pump Turns On Sunday at 8:03 AM
Pumps and Tanks Well Forum & Blog. Water is life. Pump at 0psi Sunday at 5:51 AM
