We are in the process of building a new house. The house is a 2 story 4 bedroom 2.5 bath house. The calculated peak water flow is 15 GPM. We have had our well drilled and are now looking for the pump for the well.
Details/Plans for the well:
Depth: 220ft
Static Height: 105ft
Recovery Rate: 8GPM
Well Diameter: 6in
Well Distance to House: 80ft
Elevation from Well to Pressure tank: 0ft
Pressure Switch: 40/60psi
Pipe Size: 1in
Voltage: 220V
We are planning on installing a cycle stop valve with a 4.4 gallon pressure tank.
We are also thinking on putting the pump at 200 ft, but open to other suggestions.
We have had one person tell us a Goulds 7 GPM, 1 HP pump to use, but someone else told us this pump would be too powerful for the recovery rate. They suggested instead a Goulds 5 GPM with a 0.75 or 1HP pump to use instead. My only concern with the smaller pump is not having enough water flow in the house.
We are open to other brands of pumps as well. Any help in regards to the pump sizing would be greatly appreciated.
Depth: 220ft
Recovery Rate: 8GPM
Well Diameter: 6in
Pipe Size: 1in
Voltage: 220V
