Roland Nickelson
I joined this forum hoping someone can answer my question. I had an in well pressure tank installed a couple years ago, can't reach the folks who installed it. I noticed on my drip irrigation my flow fluctuating up and down, after checking on the web site I read they recommended a 50-70 pressure switch so I bought a Square D Pumptrol 50-70 and installed it, the old one was a 30-50. I noted there is constant 60# on the gage, that must mean the tank has a 60# constant pressure valve, I was able to adjust the switch where I got a constant flow on drip irrigation emitters, but the pump still quick cycles, but the pressure stays constant, as soon as the pump kicks off I can see the diapram on the switch moving up and in a few seconds closes the contacts and the pump starts again, on and off every few seconds. When I start a zone on my yard irrigation system, the pressure drops and the pump kicks on, pressure comes up to 60# and pump stays on, does not cycle on and off. I've adjusted it about 3 turns and does not make a difference. The well is used only for irrigation. I hope someone can address my problem.
