Pump seems to be losing prime while on
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by User2342, Jun 14, 2021.
  1. User2342
    User2342 New Member
    May 1, 2020
    Massachusetts
    I have a 1hp jet pump that is pumping up from a shallow well. The well is about 20ft deep and water ranges from 5-10ft down. I have a foot valve at the bottom of the suction pipe and a check valve above ground in front of the pump. Discharge side goes to irrigation system and pressure tank.
    I am having an issue with the pump only pulling water for a few seconds and then it goes away. If I wait 20-30 more seconds it comes back. I made a video that can be seen here:
  2. banjo bud
    banjo bud Member
    Sep 24, 2018
    South Carolina
    Looks to me like your either running out of water or else you pump is starting to fail. If you’re running out of water, is your foot valve deep enough? Can you see water in the casing above the foot valve? I don’t think it’s a prime problem.
  4. User2342
    User2342 New Member
    May 1, 2020
    Massachusetts
    The foot valve is about 16ft down (about 2ft above bottom of well) with the water line about 5ft down.
    When you say running out of water, do you mean that my pump is pulling water out of the well faster than it can replace itself? If that's the case, is my best option a smaller pump?
  5. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If you can see down the well check the water level when this is happening.
  6. User2342
    User2342 New Member
    May 1, 2020
    Massachusetts
    I can't, but I have a cap on the side of the casing. When I removed that I can hear it sucking air right before I lose the water so I think I must be over drawing my well. The top of the casing where the suction pipe comes out isn't air tight. If I seal that, would the low pressure that will develop in the casing help draw water out of the ground more rapidly?
    I have a ball valve on the discharge side that I can choke down and get continuous water around 8-10GPM, but it has to be almost completely closed so it is hard to narrow in on. I am thinking of downgrading my pump with the thought that saving electricity from 1hp to 1/2hp will pay for itself over a couple years. The other options I'm considering would be a dole valve or a pool diverter valve that lets me more accurately chock the flow. Any thoughts on which direction I should go?
    Thanks for all the help.
  7. WorthFlorida
    WorthFlorida The wife is still training me.
    Oct 28, 2009
    Retired
    Orlando, Florida
    On first start of the pump after it has not been used for a while, does it pump water immediately or is it self priming? The well casing, is it just an open pipe at the bottom or is there a well point?
Similar Threads: Pump seems
Pumps and Tanks Well Forum & Blog. Water is life. Deep Well Jet Pump Amp Draw Seems High Apr 19, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Have a F&W submersible pump seems to have stopped, replaced QB control box Jan 30, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Constant pressure pump seems to run way too often - almost will not stop Apr 11, 2009
Pumps and Tanks Well Forum & Blog. Water is life. ?Pump? seems to turn on and off May 25, 2008
Pumps and Tanks Well Forum & Blog. Water is life. I have a new well & some plans. Please critique & offer pump suggestions Yesterday at 9:52 PM
