Nowell Dunwell
Bought a house with a well, that's 150' deep, about 50' from the house. House is on a slab and has been "remodeled" numerous times by questionable means and I'm now redoing everything.
From what I can tell, the main water pipe that comes from the well, T's off somewhere UNDER the slab. One end comes up in a closet, where all the main water pipes (bathroom, kitchen, laundry) are located. Water softener, filter, and pressure tank are in there too. The other end that gets T'd off, apparently feeds the spigot that runs outside. I haven't found where it feeds up from the slab yet, but suspect it's behind/under/in a previous outside wall that's part of a porch now.
Everything (pipe-wise) in the closet was just replaced starting at the main pipe in the floor going up. So, it immediately T's off to the pressure tank, then filter/softener, and water heater; cold T's off to kitchen/bathroom/laundry while hot goes to each as well.
I have a ball valve right at the main pipe on the floor, and few other ones at certain points downstream too. If I close a valve after the pressure tank, I can pressurize the system w/o having anything else on (kitchen, bathroom, etc.) however the outside spigot is still on the line and it is affected by the pressurized tank.
So, for simplicity's sake, I shut the valve AFTER the pressure tank but the water line is still pressurized for the spigot. I go outside, and turn the spigot on from a 45 psi static pressure i.e. everything has been off for awhile. Water pressure starts at 45psi and runs good for about 30 seconds roughly. WHEN the pressure switch clicks, the pressure gauge shows it abruptly dropping to 18-20 psi. Outside spigot reflects the drop by less flow. If I leave it running, it'll eventually build pressure back up.
Tank and pressure switch appear newer (probably within last 5 years) although the house sat for 2 years, unoccupied, and suffered at least the first winter with water in the pipes and there was numerous cracks in the copper. I cleaned up the flow of the pipes (50 years worth of newer/older stuff cobbled together) and ran new everything, however the "T" for the switch and pressure gauge were untouched.
I've run the well 24 hours to clear it (water is clear) and even power washed the siding all day Saturday. Only issue so far is that drastic drop in pressure when the switch opens. If not using water, the system stays at 45 psi though it's crept to 48psi a few times.
Hopefully that makes sense?
