ScorpioCowgirl
I'm having problems with my pump/pressure switch, can't afford the outrageous service fee, so thought id try here.
In my main breaker box, there are three wires connected to a double breaker labeled 50. Yellow connected to main ground, red and black connected to breaker. This wire runs to my well house, and connected to a junction box, well wrked fine.
Water line cracked so I flipped breaker, repaired line. As my assistant turned on power, there was a spark from under the pressure switch cover, we powered off immediately. Have tried to reengage system with no result. My uncle removed the junction box, wired pressure switch direct to main breaker. Tried well direct to main breaker. Not sure wires are correct. Yellow is ground, the original yellow( from breaker) was never hooked to pressure switch. Yellow from well hooked to switch. When powers on. If yellow( main) touches pressure switch it sparks. Help please.
