i bought this house last october. it has spring water about 250 feet from the house. it is basicly a straight horizontal run for the water. the spring itself is not very big. it is got cement cylinders that are maybe 3 feet around and maybe 4 foot of water in them( there is a larger holding tank behind mine that has more water, but thats a different nightmare for another forum). Anyway, since April I have been trying to get water to this house. Most of the summer i was able to draw just enough water to water my plants and fill a few jugs, but was also filling 55 gallon drums to be safe. Now i can barely get enough water to water one plant.
I bought a new 1 HP floforce water pump on ebay, hooked that to pressure tank and was able to get water running but not fill into pressure tank, so i bought a new 20 gallon pressure tank. Still hit and miss getting the water. Of course, i foolishly try to adjust the pressure gauge. With that being said and done, i bought new pressure gauge, put new foot valve , new pressure gauges, still, wont stay pulling water. i bought another 1.6 hp pump, nothing. i ordered another pump from a place on line, i ordered 1.5 hp and they sent me 1 hp pump and needless to say, i still have no water. yes there is water in spring. i tried hooking up two pumps, it will tart to draw but not enough to do nothing. I only have hose coming off the holding tank i been getting water from. for a couple minutes, the water tried making it to the house first floor but every shark bite fitting i put in leaks, took them off put in quest fittings, yup, they leak too.
it is painfully clear, wishing you were a plumber does not make you one/ I need some serious advice. i cal;led a couple of local plumbers and no one wants to mess with the jet pumps. PLEASE HELP!!!!
