No Sir, it's 2" PVC casing. I double checked all the pipe for cracks and doped all the threads when we put it back together, took the jet apart, cleaned it and put the new leathers on it. Nothing corroded or damaged. Footvalve was clean and open/closed smoothly which was reassuring because the one I ordered didn't fit. Put it all back in the hole and filled the drop pipe up with water. It held water at the time. Left it to soak hoping those leathers would eventually seal off. Either the leathers never seated or that foot valve pulled a fast one on us because it's guzzling all the water I can get into it since we remounted the pump. It's going to have to wait till next weekend at this point. We'll pull it up again. I didn't think to work those leathers to loosen them up, worth a shot. New foot valve, shorten the drop pipe a few inches, ordered a new adapter for the pump. Seemed like that pump adapter(?) was in worse shape than any other piece I looked at. It's pretty corroded and pitted up.
Still don't know if the pump itself got messed up the night it ran dry so and won't until I can get the thing to at least try to pump water.
While I have you here...It's a 1hp sta-rite and I love this pump. It's a workhorse. They're getting harder and harder to find up here. I can't even find a rebuild kit for the thing. I got the part No. from Pentair and looked till I was crosseyed. The prices on the few I have found in my area have almost doubled since I bought this one in 97. If I have to have another pump my better half wants to go horizontal to save money. Is it even possible to run a horizontal pump with a 2 inch single pipe system? I know I'll lose a lot of output and pump life by downgrading the pump. I can live with that. Just need to get it going again.
On the off chance that the casing itself is cracked. I have a 2nd well about 15 ft from this one. It was drilled first and for some reason it almost immediately started sucking sand like crazy. My well man at the time put a screen or something in it but said he couldn't guarantee it would hold and since it was a brand new well he dug me a 2nd at no cost. Been running off the 2nd for 20 yrs with no major issues till now. Would that 1st well be worth uncapping and blowing out/sanitizing after all these years?
