Toby Hanson
Hi all,
I put in a new pump a month ago, a 3/4 HP submersible. It's 90' down in a 100' well. It worked fine from that time until this weekend. I was out of town over the weekend with my wife and got a message from my sister saying the water was off. I got home today and started troubleshooting. One of the fifteen-amp fuses in the disconnect box was blown. I replaced it and closed the pressure switch manually. The pump came on for a few seconds but then it quit and won't come back on. I checked the fuses again and they're both good. I checked resistance on the wires to the pump and everything is within spec. I got a replacement capacitor for the control box just in case that was the problem but that didn't change anything. I traced the power path with my tick tracer and, with the pressure switch closed, there's voltage all along the wiring from the disconnect through the pressure switch to the control box and down to the pump. Even with the voltage on the wires the pump won't run. I've tried troubleshooting everything I know how to do on this system and I'm out of ideas. What else should I try?
