Have a 1 1/2 year old Sta-rite pump, S5P4HS07231-01 (3/4 HP, 230V, 3 wire) that is set at 280 ft down in 300 ft deep well. Well is for a vacation cabin at 7900 ft elevation in mountains, so is not continuously used. Has been working fine since install by professional installer, last used in November. Late this February, turned it on and no water came out, i.e. well pumps into a 200 gallon "cistern" or storage tank. The Pump Saver Plus that controls the pump shows via its reader or "Informer" that pump is drawing 5.4 amps. I also removed the well cap and measured the current using a clamp meter on black wire to be 5.7A (2.7A on red wire, 6.0 A on yellow), 238Vac. With well cap removed and pump turned "on", couldn't hear any "noise" in well. Measured static water in well at about 40 feet, so plenty of water in well. Any ideas what could be the problem? If check valve on pump was stuck wouldn't the pump current be lower and wouldn't Pumpsaver shut it off and give error? (Pumpsaver shuts it off below 4.8A). How common for pipe above pump to be broken or severely cracked? If impellers were bad would pump still draw current?
Thanks for any comments,
Glenn
P.S. The other pump located in the 200 gallon storage tank that pressurizes the house continues to work fine and is controlled by a Cycle Sensor. (yes I like the Cycle Sensor better because it directly displays the pump current).
Glenn
