Tyler Kukko
Hi all, first time poster here and trying to get more knowledable with plumbing. Have an issue with my set up. I have a Gould’s submergable pump and a Water Worker bladder tank. I am from Upstate New York and the weather has been funky the last month or so (warm to very cold to warm to cold, etc). Every time the temperature is over freezing my pump continuously cycles. I replaced the pressure switch and that didn’t help. The pump will build pressure to 50 and cut off back down to 30psi and continuously does that with water constantly cycling. There are no leaks inside of the house, so I was wondering what else this could be? Again this only seems to happen when the temperature is above freezing
