warpspeed
Hello,
I have a Gould J7S shallow well jet pump. When the pressure drops to the low set point to start. The pump cycles on for a split second, then off, then on again and stays on until the high set point is reached. The pressure switch is mounted on the pump and a tube goes from the pressure switch to the base of the pump. I flushed the tube to make sure there were no blockages and also cleaned the contacts. The condition still remains. My other though is there might be air in the pressure switch causing this to happen.
Any suggestions to remedy this issue would be appreciated.
Thank you,
David
Thank you,
David
