Mr B
I have an older pumptrol 20/40 pressure switch and a well-x-trol model wx 250 pressure tank. Every thing is working fine as far as water pressure, bath, toilet, sinks, etc but I was looking at the pressure gauge the other day and I notice that my tank will pump up to 40 psi and cycle off but it drops down to 10 psi before it cycles on.
I drained the water from the pressure tank and the tank pressure is at 19 psi. So I filled the tank back up with water and ran a faucet and the pressure dropped to 10-psi and the pressure switch cycled on, went to 40 psi and cycled off. So I ran the faucet and same thing off at 40 on at 10.
Can this be fixed and/or its not a big deal? I thought there should only be a 20 pound cycling difference between on/off.
Thank you
Thank you
