Yes the motor is thermally protected. It has an auto-reset overload that resets itself after a minute or so. That is when you hear the click and the pump tried to start. Typical pump failure. The pump cycles on/off for a few years with the old pressure tank system. Once you have used up all the on/off cycles, the overload starts to trip. You can try a new control box, but most likely you will need a new pump/motor. And if you don't want history to repeat itself, figure out how to stop the pump from cycling and it will last much longer.
