A coworker who lives in the same neighborhood as me recently had his pipes replaced and the plumbers determined that his water pressure was registering over their 100 psi gauge. I am now wondering if my pressure is too high (I'm sure it is) and I would like to install a prv and I believe an expansion tank on the water heater.
Present state: copper supply up through the floor with shut off valve and an adapter to convert to 3/4" cpvc.
Is it better to hook the prv up to the end of the copper and add a valve/permanently installed gauge and then another shut off valve or should I do it in cpvc and use adapters.
Any suggestions for the expansion tank? I will be mounting it right before the cold line enters the water heater and it will be mounted horizontally on the wall.
I will post pictures later tonight, thanks!
