Proper priming and layout procedures
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by catldavis, Nov 23, 2020.
  1. catldavis
    catldavis Member
    Sep 17, 2016
    Florida
    Hello all, I'm installing a vertical deep well pump. I have the pump attached to the casing and the pump wired. I've never installed a pump before, so I'm a little nervous that I might create a catastrophic failure. When I read the pump manuals for the proper start up procedure, one says to open all the faucets in the home and another stated don't. They both start with removing the pressure gauge, close regulator valve and pour water through the pump. Reinstall the gauge and start the pump. My question is, should spigots/faucets be open or closed as the pump is trying to pump? FloTec's manual says: NOTICE: Open water system faucets before priming pump for the first time. Goulds manual doesn't say anything about opening the faucet.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Open the faucets.
Similar Threads: Proper priming
Pumps and Tanks Well Forum & Blog. Water is life. Found old water well on property May 21, 2020
Pumps and Tanks Well Forum & Blog. Water is life. Pumping Long Distance Proper Design Feb 22, 2019
Pumps and Tanks Well Forum & Blog. Water is life. Well/Pump on new to me property Feb 17, 2019
Pumps and Tanks Well Forum & Blog. Water is life. Water well in basement improperly abandoned Aug 13, 2018
Pumps and Tanks Well Forum & Blog. Water is life. What constitutes a "properly installed CSV"? Nov 16, 2017
